Magnetic Ground Clamp
   / Magnetic Ground Clamp #1
Meriasek
Was watching some welding videos on youtube, and there is a gentleman who has a magnetic ground clap. It's a circluar magnet that attaches to wherever. Do any of you guys use such a device, and if so where can I get one?
   / Magnetic Ground Clamp #2
4" Magnetic Ground Block
Bruce
   / Magnetic Ground Clamp #3
Look around on line or your local welding supplier.
   / Magnetic Ground Clamp #4
I tried one for a while and they work good on a clean metal surface, If you have any paint or dirt or grease issues, they are not worth 10 cents. Ken Sweet
   / Magnetic Ground Clamp #5
i tried one also....wasnt too impressed. my gripping clamp gives me a great positive grounding..... not sure why i bought the magnetic one..guess it was just another gadget that i thought i needed.
   / Magnetic Ground Clamp #6
I've never had any luck with magnets and welding. They just seam to collect every small piece of steel, whether it be cuttings, grindings, or splatters, the magnet finds them all.
   / Magnetic Ground Clamp #7
Tried one once. :)
They are very good for picking up nails in in your driveway. :D :thumbsup:
   / Magnetic Ground Clamp #9
From the posts, I would tend to consider a switchable magnet if such a thing is made for a ground clamp, but even then you still going to have the paint/rust grounding problem, but realistically that is true for mechanical clamps also. A switchable magnet is typically used in machine shops to hold dial indicators at various locations.
An example of the mentioned magnet can be view in this link.
http://www.diytools.co.uk/diy/Images/DB_Detail/_90714_187687.jpg
David from jax
   / Magnetic Ground Clamp #10
Magnetic grounds are handy if you cant put on a ground clamp like if you wanted to weld on a large sphere or large pipe and ground wouldnt reach the end, otherwise clamps are best. As for paint, rust etc, even with a clamp style, the area needs to be clean to avoid arcing the ground area.
2015 Toyota Camry Sedan (A51694)
2015 Toyota Camry...
2025 AGT YSRT14 (A50123)
2025 AGT YSRT14...
2018 BIG TEX 70CH 84" X 20' CAR HAULER TRAILER (A51247)
2018 BIG TEX 70CH...
1988 DRESSER 515C WHEEL LOADER (A51246)
1988 DRESSER 515C...
Bush Hog R0-720 Roll Over Box Blade (A51691)
Bush Hog R0-720...
