magnetic drain plug, Penzoil Hydra Trans
   / magnetic drain plug, Penzoil Hydra Trans #1
JRP
Platinum Member
South Texas
Kubota M6800
I just received a Kubota M6800 4wd and had a thought about adding a small magnet to the various drain plugs at the 50 hour change. My Ford Explorer has a magnetic plug for the differentail, and I'm amazed at the ghray goop that comes off of it.
I found a powerful, very tiny cylindrical "rare earth" magnet at Radio Shack. About 3/16" OD. I thought this would easily fit in a drilled hole in the plug and could be staked over with a center punch. Any thoughts?
Also, Wal Mart sells Penzoil Hydra Trans universal tractor fluid that that is suppost to meet the requirements for UDT. Cost is $30 per 5 gallons. Does anybody use this?
   / magnetic drain plug, Penzoil Hydra Trans #2
Can't comment on the Hydra-trans, but I've heard mixed results from the magnet gig. Problem is that it sits on the bottom of the reservois where stuff tends to settle anyway. Doubt seriously if it would catch anything that was "in transit".
If you can be sure that you're not going to lose the magent inside, it probably doesn't hurt though. And if it gives you some peace of mind, go for it.
The GlueGuy
   / magnetic drain plug, Penzoil Hydra Trans #3
The Kubota L4850 I recently changed the hydaulic oil on came with big magnets on the plug, much more substantial then your Ford explorer. They came out with a considerabe amount of very fine metal filings. The magnets do a wonderful job of pulling metal out of the oil,gtransit or not. Rat...
   / magnetic drain plug, Penzoil Hydra Trans #4
<font color=blue>...Also, Wal Mart sells Penzoil Hydra Trans universal tractor fluid that that is suppost to meet the requirements for UDT. Cost is $30 per 5 gallons. Does anybody use this?...</font color=blue>
Jim,
I've used Pennzoil in my MF165, but have used the last couple years in both Massey's... the 5 gallon pails from Walmart's sister company Sam's Club by Quaker State... about $16.xx or $17.xx for a 5 gallon pail. {has/meets Kubota UDT spec's on label}
{Pennzoil & Quaker State are the same company}
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2017 JOHN DEERE 6120M TRACTOR (A51406)
2017 JOHN DEERE...
2017 TROXEL 130 BBL STEEL VACUUM TRAILER (A53843)
2017 TROXEL 130...
2019 CHEETAH T/A CHASSIS TRAILER (A53843)
2019 CHEETAH T/A...
2016 IZUZU NPRXD S/A BOX TRUCK (A52706)
2016 IZUZU NPRXD...
