popsjohn
I recently purchased a MacKissic SC-183 Chipper Shredder at a Lancaster County PA Mud Sale. I knew it had some parts missing such as the battery, battery holder and belt guard but I got it for a good price and I knew the parts would be available. When I got it home I purchased a battery and started up the BS 16HP Vanuard engine. It started but smoked like crazy. Figured out it had gasoline in the crankcase. After oil change and carb rebuild engine runs fine. I also needed to reverse the hammers and replace some broken ones. It seems to shred very well.
My problem is the chipper blades. This is an older unit with two chipper blades. I determined that the gap between the wear plate and blades was too wide. Could not adjust to the correct 1/16" so replaced the wear plate. Chips better but still not what I think it should be. I attempted to remove the blades following instructions I was able to download. I can't get the bolts to move. Used heat as instructed but being a novice at this I don't know how much heat to apply. Any help or suggestions would be appreciated.
John
John
