Backhoe Machine won't go into gear
   / Machine won't go into gear #1
BigBrett
New Orleans LA
Ford 545 backhoe
I have a 1981 ford 545 rubber tire backhoe. When I put the machine in forward it goes forward. When I go to reverse it goes in reverse. After about 2 or 3 times of this routine it won't switch into forward or reverse. If I kill the motor for 1 minute and restart it, it works fine again until I switch it 2 or 3 times from forward to reverse. What could be the problem?
I changed the transmission filter figuring it was clogged and no luck. Its almost like when I shut the machine off some type of pressure releases and the machine works again only until the pressure builds up again.
The only other thing I can think of is something going bad with the forward/reverse lever. Any help would be appreciated.
2009 Ford Ranger Pickup Truck (A48081)
2009 Ford Ranger...
New/Unused 4ft Bush Hog BH114 Rotary Cutter (A48837)
New/Unused 4ft...
UNUSED MOWERKING SKID STEER PALLET FORKS (A50460)
UNUSED MOWERKING...
PALLET OF MISC COVE BASE (A50460)
PALLET OF MISC...
NEW 2024 LOAD TRAIL 83IN X 20FT Tandem Axle Equipment Trailer (A50397)
NEW 2024 LOAD...
2016 Ford Explorer AWD SUV (A48082)
2016 Ford Explorer...
