M9000 Kubota Clutch
   / M9000 Kubota Clutch #1
gatractorman
Cleveland GA
varies never keep one long enough to post here lol
How much time for accomplished mechanic to replace clutch and pressure plate on this Kubota. Cab tractor, 4x4, FEL is off but not brackets. Thanks
   / M9000 Kubota Clutch #2
The cab probably doubles the time (16-24 shop hours) plus it needs a shop with a crane or other means of handling the cab. I dunno if the M9000 has a removable front portion on the cab - my Laurin would be easier to unplug etc and lift off whole for splitting the tractor. I'd call around to some dealers to see who's done one and how long it took.
   / M9000 Kubota Clutch #3
GA,
Unless the subframe keeps the bellhousing split from happening easily, this is a 4 hour job by someone who has done it before and 6 hours for your first time.
Have some help to line it up correctly when you have installed the new clutch and don't pull it together with the belhousing bolts or you may get to do it over.
Good luck!
2009 Kubota KX080-3 Mini Excavator (A51573)
2009 Kubota...
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
TEST BID LOT (A50775)
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
19101 (A51694)
19101 (A51694)
2012 VANGUARD 53FT DRY VAN TRAILER (A52576)
2012 VANGUARD 53FT...
