M9000 hyd.shift
   / M9000 hyd.shift #1
bonnieleejones
We own a 2003yr. M9000 Kubota with hyd. shift and LA1251 loader. Problem with shift and loader. When tractor is 1st. started loader works fine for few minutes then becomes sluggest. After warming up for several minutes it works better. Have bled air from system by manuel rec., changed fulids and filters. Filters are tight. When draining fluid, I also removed a plug -manuel said it was to drain water from cluch- got aprox. a qt. of trans. fluid from that sight. Rest of fluid from regular drai plug. I assume the tractor has a wet cluch. Neither our orp. manuel or shop manuel has any info. obout hyd. shuttle or wet cluch. Would appreciate any help or information. Just an old Ky. boy. Tractor has 450 hrs. on it.
2015 DODGE RAM...
2000 MACK RD688 TRI AXLE DUMP  TRUCK (A51222)
2000 MACK RD688...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A50322)
2025 Kivel 48in...
2015 Peterbilt 579 (A49461)
2015 Peterbilt 579...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2018 Ram 5500 Bucket Truck 4x4 with Versalift VST40 - 45FT Rotating Bucket and Jib Winch (A51039)
2018 Ram 5500...
