Loader m7060 HDC 12 shuttle disengage button option
   / m7060 HDC 12 shuttle disengage button option #1
m7060
London, KY
Kubota M7060
Is there an aftermarket or OEM accessory / option for a shuttle disengage button to mount on the FEL control stick? They are nice when doing loader work.
   / m7060 HDC 12 shuttle disengage button option #2
Like on a 580 case?
Brett
   / m7060 HDC 12 shuttle disengage button option #3
Like on a 580 case?
Brett
Exactly what I was thinking!
I think you would have to go through the WSM wiring diagrams and see if the shuttle was electrically (neutral) controlled, somehow I doubt that Kubota would have gone this way as they build tractors, with optional FEL/HOE, so their design is more to do with tractor/traction drive than FEL operation.
   / m7060 HDC 12 shuttle disengage button option #4
Does your shuttle lever operate an electrical switch/control, or does it go to a linkage to the tranny? If it's not electrical, I doubt you'll have a chance.
   / m7060 HDC 12 shuttle disengage button option #5
Can you please explain the benefits of this? I'm not sure I understand. :)
   / m7060 HDC 12 shuttle disengage button option #6
On a backhoe as you pull into a pile of dirt and press the button. It'll disengage the transmission so you can hit the throttle to make the hydraulics works faster and get the bucket raised. Put it in R and let go of the button and away you go. Increase productivity quite a bit when you get the order down
Brett
2001 International 4700 Aircraft Fuel Truck (A46683)
2001 International...
Landhonor Gasoline Water 3" Water Pump Trash Pump (A47371)
Landhonor Gasoline...
2024 Ford Explorer AWD SUV (A48082)
2024 Ford Explorer...
2001 KENWORTH T800 TRI AXLE TANKER TRUCK (A50046)
2001 KENWORTH T800...
2025 Ford E-450 Super Duty Van, VIN # 1FC4E4KN3SDD00016 (A48836)
2025 Ford E-450...
2012 JLG G5-18A TELEHANDLER (A50046)
2012 JLG G5-18A...
