Price Check m7040sud
   / m7040sud #1
harrelson
been reading this forum for a year gathering information. need help on the price of a left over 2009 M7040sud with loader 8x4 transmission i rear remote grill guard tractor was used a yard tractor on dealers lot . 12 hours non turbo engine dealer gave me a price of $27,000 cash.
I still cannot tell the difference in the m7040sud and the m7040hd other than a turbo and different transmission. thanks for any help
Bob
   / m7040sud #2
Maybe this will help:
M Series
DT-1 = Dual Traction 4wd, ROPS model with IC/Shuttle Transmission (M7580/M9580)
DTL = Dual Traction 4wd, Low Profile (for orchards)
DTM = Dual Traction 4wd, MUDDER (for specialty, row crop and vegetable)
DTN = Dual Traction 4wd, Narrow (for vineyard/orchard tractor)
DTN-B = Dual Traction 4wd, Narrow wheel tread with Bi-Speed Turn
F = Two Wheel Drive
F-1 = (-1) = Larger two pump hydraulic system
FC = Two Wheel Drive Cab Model
F-CS = Two wheel drive with Creep Speed (Ag. tires or as Turf Special)
HC = High Clearance (2wd M7950 only)
HD = Hydraulic Shuttle, 4wd
HDC = Hydraulic Shuttle, 4wd, Cab
HDCCS = Hydraulic Shuttle, 4wd, Cab, Creep Speed
L = Low Profile
ML = Mechanical shuttle, Low profile
MDT = Mechanical shuttle, Dual traction 4wd
MDTL = Mechanical shuttle, Dual traction 4wd, Low profile
MF = Mechanical shuttle, Two wheel drive
OC = Orchard model
S = Synchro-Shuttle, 2wd
SD = Synchro-shuttle, 4wd
SCS = Synchro-Shuttle, 2wd, Creep Speed
SDN-B = Synchro-Shuttle, 4wd, Narrow with Bi-Speed Turn
SDNBC = Synchro-Shuttle, 4wd, Narrow with Bi-Speed turn, Cab model
SDNBF = Synchro-Shuttle, 4wd Narrow with Bi-Speed turn, Foldable mid-mounted ROPS
SU = Special Utility, 2wd
SU-R = Special Utility 2wd, Rigid ROPS
SU-F = Special Utility 2wd, Foldable ROPS SU-TF = Special Utility 2wd, Turf Special
SUD-R = Special Utility, 4wd, Rigid ROPS
SUD-F = Special Utility, 4wd, Foldable ROPS
SUMDT = Special Utility, Mechanical Shuttle, 4wd
SUDT = Special Utility, 4wd
W = Wide Row
H = 2WD, ROPS (Note: All H-Models are Std. Swing Shift 16F X 16R speeds)
HC = 2WD, CAB
HD = Swing Shift, 4WD, ROPS
HDC = Swing Shift, 4WD, CAB
DS = Dual speed, ROPS (Note: All Dual Speed models are 32F X 32R speeds)
DSC = Dual speed, CAB
SDSCC = Dual speed, CAB, cold weather w/high amp alternator and creep speed and second remote valve
SDSC = Swing Shift Dual Speed, CAB DSDF = Dual Speed, 4WD, ROPS
SDSL = Dual Speed, 4WD, Low Profile
M-Series Notes:
Suffix "1 models are the second generation "Wide Cab tractors. Cab is 5.7 inches wider than first models.
Suffix "2 models are factory equipped with 540 / 1000 RPM PTO kits. M95S and M105S:
The "S represents the model/tractor class in general is no specific meaning, however it can be applied to "Swing Shift as the base transmission on all "S models.
   / m7040sud #3
   / m7040sud
the tractor has steel rims 16.0-30 R1 ag tires ,beet juice for fluid in rear tires , rear light,grill guard, 1 rear remote
thanks for the model break down codes
   / m7040sud #5
Sounds like a nice tractor and decent price.
   / m7040sud #6
for the money, i think that line is a good solid machine compared to the higher prices grand L series with all the frills. on the tranny, it is (i believe) not synchro in 1st or 2nd. can't say on the price, but it seems good. for overall utility work i think you can't go wrong.
   / m7040sud #7
I recently purchased the same model, except the one I bought had the cast rear wheels and no rear remote. The cast wheels and remote are both fairly expensive options, I'm guessing around 1k each, so it might be a wash between our two machines in terms of price. Everything else was the same (grill guard, transmission, 4wd, loader). The machine I bought was new, with no real hours on the tach (1.2 hours or something), but not sure if it was technically a 2009 or 2010 model. I bought it in November of 2010 for 29000, with 0% financing. If I would have paid cash, I think I could have paid a little less. I negotiated quite a bit and I think I got the local dealer down as low as he would go. I could have gone to a dealer outside the area or outside the state to get a lower price possibly, but I wanted to form a relationship with the dealer and have him available in case there are any problems. And that has already paid off. The right rear tire, when I first got the machine, had a flat spot. So, when I ran it down the road at a higher speed (>10), the flat spot would cause a bit of a bounce. I suspect the tire simply had a rare defect. I called the dealer and they were able to come out, take the tractor for a ride, and confirm it. If I had gone to a dealer out of the area, this issue probably would have been much more difficult to handle.
So, on the price, that seems fair. I'd look over the machine and make sure they didn't abuse it when they used it. But not much could be done to it in 12 hours. Take it for a ride, shift through all the gears, back and forth.
And even if you do hear of someone getting that machine for 500 less somewhere, there is value in having a dealer your comfortable with and that is convenient to get to.
And overall, I'm very happy with the machine. It replaced a 50 year old massey for me, so I was used to a basic tractor. This one offered several nice upgrades from the massey, but it's still a basic tractor, quality built.
   / m7040sud
Ok I finally made the decision to get the M7040 HD with FEL, cast ag tires,QA bucket ,block heater .
We decided on rim guard for the tires, made the deal. Ok thought I was done . Dealer called today and told me the tires had all ready been filled with calcium chloride.
they are making a price adjustment of $500 if I take these tires.
As long as the fluid is above the top of the rim the calcium chloride should not hurt the rim right?
   / m7040sud #9
You are better off with the tires filled even with the cast wheels. You'll thank yourself one day.
If you get a $500 discount on top of it then all the better. You might put that advantage to a Kubota QA fork lift attachment. That's another "you'll thank yourself one day" situation.
   / m7040sud #10
Congratulations on your new tractor.
We use to use calcium chloride in our tractors and all of them developed corrosion over time though it took a very long time.
2023 CATERPILLAR 299D3 SKID STEER (A51242)
2023 CATERPILLAR...
2016 WITZCO RG-35 RGN LOWBOY TRAILER (A50459)
2016 WITZCO RG-35...
Wolverine Mini Skid Steer Combination Bucket (A50514)
Wolverine Mini...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
