M7040 STEERING PROBLEM
   / M7040 STEERING PROBLEM #1
Muleskinner
Pioneertown, So CA
2015 KUBOTA B2650ROPS
Today while working on a job site I lost my power steering for a few seconds. It happened four times in about an hour. It felt like it does when the power steering goes out on a vehicle with power steering. The steering would get real hard to turn right or left. Then the problem would go away by itself. My dealer is researching the problem and is supposed to call me. Has anyone had this problem with their M series tractor? The tractor only has three hundred hours on it. I just changed the hydraulic fluid, including filters, about one hundred hours ago. I know the power steering is hydrostatic and works off of the hydraulic system. It does not have a seperate pump.
   / M7040 STEERING PROBLEM #2
did the hydraulics go at the same time, for a start i would check the transmission oil level, if thats ok throw a set of hydraulic filters on it and check the suction strainer ( you will need a clean oil catch drum or bucket because you have to drop the oil) if they are ok take it to the dealer and jump up and down a lot. if its not a oil supply problem and its still under warranty get them to fix it, thats what warranty is for after all.
This happened when I was trying to get turned around in a tight area. It happened only during a "lock to lock" turn. I think it may be a sticking relief valve or something like that. I just changed the hydro oil and filters 100 hours ago. I do not think dirt or foriegn material is the problem. And no, I did not loose my hydraulics at the same time. At least I don't think so, as my gannon was up, as was my FEL.
   / M7040 STEERING PROBLEM #4
My L model has a separate power steering pump on the engine but uses oil from the main hydraulics. I had a pin hole in the suction hose near the pump and gave your exact symtons.
2009 PETERBILT 388 TANDEM AXLE DAY CAB (A51219)
2009 PETERBILT 388...
2012 FREIGHTLINER CASCADIA (INOPERABLE) (A50854)
2012 FREIGHTLINER...
NEW 2022 Load Trail CH 83IN x 18FT Equipment Trailer (A51039)
NEW 2022 Load...
2017 Ford F-450 Crew Cab Mason Dump Truck (A50323)
2017 Ford F-450...
PLEASE CHECK BACK!!! ITEMS BEING ADDED DAILY!!!! (A50774)
PLEASE CHECK...
2014 Freightliner Ambulance (A50323)
2014 Freightliner...
