jclaudii
- Joined
- Apr 17, 2012
- Messages
- 135
- Location
- River Valley and South Arkansas
- Tractor
- MF35, Kubota7040, Case885, Ford 1100
First off I have looked and some of the information may be 'dated' here. I also have the kubota guy at my local dealership looking up the service interval and part numbers based on the serial # of my tractor.
This tractor has done some decent work and it's time to do the 50Hr service. No external hydraulics have been attached yet to the tractor and I would say the front end loader has only been used for some hay and some light leveling. I am contemplating doing it ourselves as we have done maintenance on other farm equipment and might as well jump in and save a few hundred on labor. The most recent info from kubota says that I do not have to replace hydraulic fluid like it says in my manual at 50HRs, just do the filters. They assured me that the magnets and new filters would catch any contaminates and most all of the 50Hr services the dealer has done they said the oil coming out looks like the oil going in. They recommend a 300hr Hyd. oil change now to supposedly keep cost of ownership inline with other makes. But they did have several years of the 50hr service interval to monitor the oils coming out and to make this decision.
First off, is there an easy instruction on how to replace the hyd fluid filters and roughly how much hdy fluid will I need? I'm thinking minimum a couple of gallons.
I see that there are several post on here for engine oil and filter so I think I'm good there! I plan to just go with some Rotella T5 15w40 (about 3 gallons) same we use in the 2500 Cummins truck.
Any step by step instruction for the fuel filters? Should I replace both the element and the cartridge or just the cartridge?
I plan on inspecting the air filter and only ordering one if I need to..
And the front end, do I just get some 80w90 at any store and replace. How much oil do I need and is there a step by step for this as well?
Lastly, we have a good size dent in the hood...make that a huge dent from a log rolling out of the bucket and hitting the hood. Luckily that is all that happened as it could have been much worse! It is a crease dent so I plan on taking the hood off and just beating it back out. Is the spray paint in can from kubota any good for touching the cracked paint up or would I be better off getting a pint or so and just prepping and spraying the whole hood like with automotive paint? Does kubota use a clear coat?
This is my first post here in the kubota forum as I only get to play on this tractor every now and then at the family farm. But I am the more capable hands on 'mechanic' the family has and I love hearing the options and opinions you guys provide to others. In the end I may just take it in for the service as sometimes they run some nice specials.
Thanks!
Thanks!
