M7030 Starting
   / M7030 Starting #1
bsekf
WNY
Kubota 7030, Long Landtrac 4700, Mahindra 5155
I have had this tractor for a year and it is temperamental to start. But, I have found that if I lower the rpm to 500 before shutting off, it will start instantly with no problem. But, yesterday, I started the tractor, backed it out of the shed, let it run for a minute and reduced the rpm's to 500 and shut it off. 15 minutes later I tried to start it and it wouldn't fire. Used the glow plugs, it turned over fast but would not fire. Now, the 7030 has a red knob, in front of the shift levers, that is supposed to be an emergency stop. I presume it shuts the fuel off if the key switch should fail. I have never used it! Hour later I tried to start it again and just for the hell of it, I pressed that red knob in, maybe 1/8 inch, and it started instantly. Any idea what is going on? I think there is a little guy in there who likes to mess with my mind!
Bill
   / M7030 Starting #2
Hard starting then starts easily when manual fuel cut-off is pressed forward sounds as if fuel was partially/nearly completely shut off.
   / M7030 Starting #3
Maybe put a little slack in whatever adjustment may be there, and make sure the linkage has enough friction to keep the knob firmly in.
My previous Kubota had a manual engine shut off, but my current L4060 does not. I should probably know how to cut the fuel or air if necessary (other than the obvious methods).
   / M7030 Starting
Thanks, I'll do a little experimenting. Wonder if it the red knob shuts the air or the fuel off? If it is air that might be the reason it is a fuel hog. The tractor runs well and works well but is hard on fuel. Uses noticeably more than the Allis 6060 did but has a little more HP and no turbo.
   / M7030 Starting #5
It looks like a rod attached to the injector pump for emergency fuel shut off. I still need to look at mine.
2012 NauticStar 21ft Cruiser Boat with 26ft T/A Boat Trailer (A48082)
2012 NauticStar...
2016 Kia Optima EX Hybrid Sedan (A48082)
2016 Kia Optima EX...
2017 PETERBILT 587 TANDEM AXLE SLEEPER TRUCK (A50505)
2017 PETERBILT 587...
2003 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A48081)
2003 Chevrolet...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A49346)
Dvorak Model 3072A...
2004 New Holland TN60A 55 HP Utility Tractor (A49346)
2004 New Holland...
