M7-131 Hydraulic whining
   / M7-131 Hydraulic whining #1
jlindsly
Kubota M7-131
My m7-131 does not whine at an idle. But if you have any RPM's on it and lift the or tilt the loader I get a pretty bad whine. Is this just the big pump or the load sensing, or is this something I should get checked out. It seems to function properly. However, I just bought this tractor and what seems proper to me might not be.
2019 M7-131
1100 hours
   / M7-131 Hydraulic whining #2
Warranty? Dealer? if you bought it from a dealer have them check it out.
Bought it used. difficult finding out if it still has warranty. Going to change all of the filters and see if maybe there is a restriction there. I had a dealer tell me that if the previous owner put non UDT oil in it, it could cause the same problem. After some digging I find that this tractor does not use the UDT or UDT2. It uses UDT HD.
12 Yard Rolloff Container (A51573)
12 Yard Rolloff...
2006 CATERPILLAR 330DL EXCAVATOR (A51246)
2006 CATERPILLAR...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A53472)
Michelin CARGOXBIB...
20ft Bi-Parting Wrought Iron Gate (A51573)
20ft Bi-Parting...
2022 John Deere 333G Track Loader (A53342)
2022 John Deere...
2021 JOHN DEERE HX14 LOT NUMBER 14 (A53084)
2021 JOHN DEERE...
