M6800 PTO
   / M6800 PTO #1
massey4mike
New Hampshire's White Mountains
Kubota M6800HD
I have a 2005 M6800 that seemed to have a problem this past winter with the PTO. Using my 6 ft snow blower would make the tractor shake and make a terrible banging noise. This summer, before the mechanic was scheduled to come and evaluate, I hooked up my 5 foot rotary brush cutter and there has been NO problem. My question is; can there be a problem with the PTO if it runs a brush cutter even under a heavy load but not a snow blower?
Spinning the snow blower by hand, under no load, turned up no knocking or tight spots. I have not hooked it back up to the tractor.
   / M6800 PTO #2
Most times that one implement shakes and shimmys, and another does not, it is the drive line. Also, you may not be able to "feel" the issue by hand. It is the high RPM of the shaft that causes the issue if it is bent, unballance, or has a bad u-joint (of course you can usually feel a bad u-joint). I would say hook up the cutter (see that it does not shake) and then try the snowblower (assuming it will shake) and if that is so, the issue is with the implement.
   / M6800 PTO #3
I remember this was a head scratcher last winter. Reading about it today, if the rotary cutter is smooth under load the pto gears and bearings are likely ok. Does the pto shaft for the blower run at more of an angle? Also if the roller chain that runs the auger is loose or worn the chain can try to jump the tops of the teeth on the drive sprocket. That can make quite a nasty bang, bang. Usually, a shear bolt fails. Rolling it by hand slowly would be smooth - trouble would show up under load. As always, prompt cheerful refund if theory is bogus - take care, Dick B
   / M6800 PTO #4
One of the most common reasons for u-joint failure is not lack of lubrication in the joint but on the shaft!
We've seen shafts virtually sieze and take out the rear of the tractor around the PTO or to take out the other end on the machine.
   / M6800 PTO
Thanks for all of your great input! Just to make things clear, everything is well lubricated, there is no chain, the blower has what appears to be a car or truck rear end for a gear box. However, the shaft DOES run at quite an angle down but the U joints are all good. It could be imbalanced. It is an old blower and owes me nothing, I will be looking to replace it!
2013 GMC Sierra 2500HD Ext. Cab Pickup Truck (A49461)
2013 GMC Sierra...
2012 International Semi Truck (A50323)
2012 International...
2014 Brent 1596T Dual Auger Grain Cart (A50657)
2014 Brent 1596T...
DeeZee Crossover Aluminum Truck Tool Box - Secure Weather-Resistant Storage for Pickup Beds (A51039)
DeeZee Crossover...
72In FEL HD Round Back Bucket (A51039)
72In FEL HD Round...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A51039)
2024 BCL...
