M6800 got hot, small pop noise, then lost some coolant and steamed.
   / M6800 got hot, small pop noise, then lost some coolant and steamed. #1
Jonerin
kabota m6800
Cant find a bad hose, could the radiator have pressurized and popped, is the cap a pressure relief type?
   / M6800 got hot, small pop noise, then lost some coolant and steamed. #2
seems like you will need to fill in and get a pressure tester that you can pressurize the system to rad cap value and look for leak. or you can make a tee that goes in the hose that has a shreader that you can fill with air with a tire chuck to the radiator cap value and search for that source of water leak.
It almost looks like the cap blew, is that a possibility?
   / M6800 got hot, small pop noise, then lost some coolant and steamed. #4
Most systems are pressurized so if relief doesn’t open the cap could be blown off.
So there is a releif that opens if the pressure fets too high?
   / M6800 got hot, small pop noise, then lost some coolant and steamed. #6
I suspect it is built in to the radiator cap on that model. Is there an over flow tank connected to the neck of the radiator where the cap screws on? If yes then cap is the relief.
   / M6800 got hot, small pop noise, then lost some coolant and steamed. #7
Ditto radiator cap should open neck seal at any pressure over I'll guess 7psi
BUYERS PREMIUM & PAYMENT TERMS (A52577)
BUYERS PREMIUM &...
2003 MACK RD688S T/A DUMP TRUCK (A51406)
2003 MACK RD688S...
2024 Doosan DX140LCR Hydraulic Excavator (A50322)
2024 Doosan...
2015 Peterbilt 337 Tilt Body w/ Dovetail (A52384)
2015 Peterbilt 337...
NEW Woods Reverse Rotation 5ft Tiller (A52748)
NEW Woods Reverse...
Deere 410G (A50120)
Deere 410G (A50120)
