Backhoe M62 questions
   / M62 questions #1
sven1277
Gales Ferry, CT
Kubota B7610
I am seriously considering purchasing this machine for my landscaping company. We currently have a 4 ton excavator, ss, mtl, and a couple smaller kubota tractors. I also have a kubota r630 but that is used in the mulch yard loading. The excavator is used daily in the field. The skid steers and tractors aren’t used as frequently. I am thinking of selling the wheeled ss and the smaller of the two kubota tractors and it’s attachments for the larger m62 machine. I have a few questions.
Does the backhoe has a quick changeover to switch from cat to jd controls? I know we can switch the hoses but still a pain. One of my main operators runs cat while the rest of use jd controls.
I will install a thumb. Are brands interchangeable or should I stick with a Kubota unit?
It will be used for plowing in the winter so the machine will need a cab. The Curtis cab looks very well made. I have a Curtis cab on an older b7610 and not hugely impressed with it, though it keeps the operator warm and dry in the winter. I also have a b3350 with a factory cab and am very happy with that.
Thanks in advance!
   / M62 questions #2
I don't think you can switch back and forth from cat to jd with out changing the hyd lines unless you add a valve .....I just got the kubota thumb with mine... Curtis does make a very nice cab.....
   / M62 questions #3
I’ve never heard the term cat vs JD controls. I’ve only seen excavator vs backhoe pattern. Second disclaimer is I’ve never even set in the seat of a M62 but I own a M59. The M59 is plumbed standard with backhoe controls. Switching hoses is the only option. It would work for a one time deal but not for swapping operators all the time. I’d stick with a Kubota thumb. I’ve never seen an aftermarket that I thought was as good. I’m not sure if it’s standard or not but definitely get a quick connect backhoe bucket. I’d like to have a tracked skid to work along side my M59 but I think you’ll be happy the M62 vs a wheeled skid steer. I also think you’ll be happy with the low ground destruction compared to a skid. Also the M59 loader is very capable compared to a tractor. I move full 68 sheet bundles of OSB and full pallets of quikrete with mine. I’ve got a 16” 24” and 36” bucket for the backhoe. I’ve got the 36” because it’s required to put in a septic but it’s about to much bucket for this machine. The 24” is by far my most used.
   / M62 questions #4
+1
I put on the Laurin cab on my M59 and it throws plenty of heat for winter operation. You might want to consider an A/C unit depending on your summers, theres about a month a year I wish I added one. Shake-n-bake.
   / M62 questions
Was there a particular reason you chose a laurin cab?
   / M62 questions #6
I’d look for a beefy ballast box like 2 tons for the M62 for plowing snow. You’ll definitely not want the backhoe sticking out in your way but my M59 is close to junk with that loss of ballast.
2015 FORD F-250XL SUPER DUTY SERVICE TRUCK (A51406)
2015 FORD F-250XL...
2015 INTERNATIONAL PROSTAR TANDEM AXLE SLEEPER (A52141)
2015 INTERNATIONAL...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
2015 Chevrolet Express (A50323)
2015 Chevrolet...
UNUSED FUTURE SKID STEER 4IN1 COMBO BUCKET (A51244)
UNUSED FUTURE SKID...
SANY SY75C EXCAVATOR (A51242)
SANY SY75C...
