Tractor was running fine, started PTO to run chipper, put on parking brake, rotated seat like normal. Got up and tractor immediately shut down.
Turned off PTO, clutch in, tractor will no longer start, intellipanel gives message "PTO NEUTRAL CLUTCH DEPRESS"
I tested the switches for the clutch, PTO Lever, and seat, all test ok. PTO switch is off. PTO lever on side of the tranny moves freely and has moved to the neutral position, there is no binding in the PTO switch or cable.
Are there any other internal sensors telling the tractor the PTO is engadged?
I hate tracing wires for bad connections - especially when the harnesses are nearly inaccessible under the cab and the tractor is sitting in a back field. Rain in the forecast starting this evening for the next 3 days...
