My machine was just in for service to fix a mystery leak coming from above/behind the left rear wheel...some sort of fitting was leaking, and while it was there the dealer told me the thumb cylinder was leaking and needed to be fixed. I also had a bit too much slop in the backhoe and had some shims put in.
So I pick it up this morning to finish this lawn renovation job I've been working on...putting down 10k SF of sod. I'm almost finished...doing some ground prep for the last of the sod. I spin the seat around to use the hoe and the machine shuts off. At first I check the seat weight sensor kill switch to make sure it's working. All good there. The display panel shows the PTO engagement light on, and the LCD display reads consecutive messages as follows: PTO, neutral, depress, brake, clutch, parking..then repeats. For some reason the machine thinks it's in PTO mode. I figured, OK, it's confused...better toggle the PTO switch, clutch, brake, parking brakes, etc. NOTHING. Dead...Won't start. Stuck in this yard. Bummer.
I call the local Kubota dealer. They tell me to find the PTO engagement switch under the PTO lever and make sure it's still connnected and looks OK. Looks OK to me. Now I'm stuck in the middle of this job and can even move the machine to get it to the dealer. There gonna send out a tech tomorrow for a field call.
Hopefully it's someting stupid and this sucker gets moving again.
-Mark
-Mark
