M59 relief valve questions.
/ M59 relief valve questions. #1
Hersheyfarm
Veteran Member
NE ky
It has 2 under the seat that I guess are the main ones but it also has three on the backhoe valve control. They are adjustable. How do you adjust them? Do you simply plumb a gauge into the cylinder line for each one and bottom it out? I am thinking mine are adjusted too weak, maybe making more heat.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2022 Magni TH5 5.19P (A63689)
2022 Magni TH5...
2013 Kubota BX2370 54in 4x4 Compact Utility Tractor Mower with 48in Rotary Brush Cutter (A61572)
2013 Kubota BX2370...
2R CULTIVATOR, 3PT (A64280)
2R CULTIVATOR, 3PT...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
