Oil & Fuel M59 Lube & Oil Change
   / M59 Lube & Oil Change #1
Chato
Remote Arizona Desert Mtns
L39/Taking Delivery M59
For anyone nearing an M59 oil change but hasn't done it, I lubed and gave mine its first oil change.
The 59s' zerks are better positioned for an easy grease job. For example, they relocated the under loader arm zerk on the 39 to an outside location for the 59.
The oil filter, oil filler cap and dipstick are together and accessible without removing the engine side cover making the oil change very easy. If you do it, make sure you get the copper oil seal rings which seat the two oil drain plugs.
2012 Kenworth W900 (HEAVY DUTY) (A52128)
2012 Kenworth W900...
Kinze 3500 8 Row Vac Planter (A52349)
Kinze 3500 8 Row...
Stehl Tow Dolly (A50514)
Stehl Tow Dolly...
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
UNUSED CFG Industrial MH12RX Mini Excavator (A47384)
UNUSED CFG...
Case CX210D Excavator (A50514)
Case CX210D...
