M57o0Kubota Farm Tractor
   / M57o0Kubota Farm Tractor #1
Pat6
Corbin, ky
M5700
Looking for a more fuel efficient Kubota. Diesel guzzler. Anybody have one?
   / M57o0Kubota Farm Tractor #2
Yes, my BX23 runs all day long on about 3 gallons of diesel. But somehow I suspect that isn't the size you're looking for. But with no information on your situation, it's as good a suggestion as any.
How can anybody help you with absolutely no information about what you're doing?
   / M57o0Kubota Farm Tractor #3
I wouldn't exactly call it a guzzler though it does eat some fuel . Your talking a57 HP 5 cyl. diesel. Mine will use about 1 gal. per hour under working conditions . Try doing the same amount of work with a gasoline eng. . I did have a Zetor at one time about the same HP as the 5700 and that used less fuel and was a much heavier tractor.
   / M57o0Kubota Farm Tractor #4
I suspect that most tractors use about the same amount of fuel to accomplish the same task. For example, my little BX23 just sips diesel, but it would take a lot longer to mow 10 acres with the BX23 than it would with the OP's tractor or my 50hp Kioti.
Wilton Heavy Duty Vise with Angle Bracket (A52378)
Wilton Heavy Duty...
2011 FONTAINE 48 FOOT STEPDECK (A53843)
2011 FONTAINE 48...
2016 JOHN DEERE 700K LGP CRAWLER DOZER (A52705)
2016 JOHN DEERE...
2008 OSHKOSH FRONT DISCHARGE CONCRETE TRUCK (A54313)
2008 OSHKOSH FRONT...
2020 Kubota RTV-X1100CW-A (A47384)
2020 Kubota...
CUMMINS ENGINE CO. N-855F DSL TIRE PUMP MOTOR (A51406)
CUMMINS ENGINE CO...
