Colby Forest
Bronze Member
Finally got to 50 hour service on my M5040HDC (4wd). Went to change the oil in the front axle and looked in the Workshop Manual (that big orange binder) and it says there are 3 check plugs: one on each of the gear cases (or hubs) and one on the differential case (or axle). Problem is my gear cases don't have check plugs, only fill holes on top and drain holes on bottom. The check holes are supposed to be near the top of the gear case just below the fill hole. The only check hole I do have is on the differential case below the fill hole.
Does anyone know why the gear case check ports are missing?
