txranger
Hi all, i'm new to the forums but have had the tractor a couple of years. This weekend, we finally broke down and bought a 6' bush hog from TSC. It is relatively light weight but I think it should be fine for our use, if i can get this problem figured out. Anyways, we got everythign hooked up and went to engage the PTO to start cutting, as soon as it engaged it broke the sheer pin on the bush hog. To say it nicely it engages ROUGHLY. Well we got a different bolt and used it, and it worked fine for approx an hour, and we never had troubles with it while the cutter was running and cutting. However, as i said it engaged really roughly and we ended up breaking 3 sheer pins over 2 days. The cutter runs fine, doesn't feel or look off balenced while it's running, the only time the pins would break is when first engaged. Is this a common thing with these PTO's? Or is the gear box on the cutter too light for the size of the tractor? We've run a post hole digger from TSC as well and have never had troubles with it. It's not a huge problem, more of a pain. Any tips or advice would be apprecitated...sorry for such a long winded post.....
