Backhoe M4900 backhoe keeps tripping the pto
   / M4900 backhoe keeps tripping the pto #1
Rubicon1000
Indianapolis
Kubota l2800 4x4 , l3301, bx2670-1, m4900
Hi guys, I have a M4900 with a bradco 509 backhoe and here lately I can only get a couple scoops of dirt and the pto lever on the right side keeps kicking off.
The tractor only has 300 hours on it and maintenance has always been done.
The stabilizers seem to be moving slower than normal and I'm not sure if there could be air in the system somewhere? Any ideas on what might be causing it?
I'm not sure how to bleed the backhoe but the fluid levels are all good and the loader is working normal. Any ideas would be much appreciated. Dan
   / M4900 backhoe keeps tripping the pto #2
Sounds as if hyd pressure is below spec's allowing pto control valve to disengage. How long since hyd filters were changed. I'll recommend getting a hyd gauge to check system pressure. Sorry but I can't remember what psi hyd pressure should be. By chance is feedback rod on 3 pt adjusted incorrectly allowing 3 pt valve to by-pass or is scv valve control handle not centered.
I'll be back out to the property this week and I'll check out your suggestions and see what I can find.
I'm probably going to go ahead and change the filters, I'm sure they are due for a change. Thanks for the suggestions. Dan
6 Yard Commercial Dumpster (A49346)
6 Yard Commercial...
2008 Ford Crown Victoria Sedan (A48082)
2008 Ford Crown...
360 Yield Y Drops (A47164)
360 Yield Y Drops...
2016 Ford Taurus AWD Sedan (A48082)
2016 Ford Taurus...
PREVIEW DATES AND TIMES (A48837)
PREVIEW DATES AND...
2021 Ram 1500 Classic 4x4 Crew Cab Pickup Truck (A48081)
2021 Ram 1500...
