Oil & Fuel M4030SU Turf Maintenance
   / M4030SU Turf Maintenance #1
BmW745On19s
Kubota M2030SU Turf Special
This is my dad's tractor and he has a few thousand hours on it, runs real good and no problems with it. It's the turf special with the nice tires on it that won't dig up the grass.
I need to know the maintenance basics for it. I'm handy at maintenance stuff and do all my own work on my Duramax.
What do I need to do on this bad boy as far as filters and fluids go? Only lord knows when the PTO fluid and filter was changed. What parts do I need and how much fluid for the PTO and engine oil and filter?
Thanks!
   / M4030SU Turf Maintenance #2
The owners manual should have the information you've requested,fluid specs and amounts,service intervals,etc,as well as detailed instructions on performing the maintenance tasks.If you don't have one,I'd highly recommend getting it.About $20 at the dealer,or Messicks or Tractorsmart online-good dealers.Good Luck!
   / M4030SU Turf Maintenance #3
Sometimes you can get a service kit with all of the necessary fluids, filters and such, but I second the need for an Operators Manual which will detail the possible need to bleed the system when changing/cleaning fuel filters, location of all the drain plugs, brake adjustment procedures and the all important Maintenance Intervals. I am sure with this and your back ground you will have no problem servicing it, Good Luck.
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
Pickup Truck Bed (A51691)
Pickup Truck Bed...
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
2007 Nissan Sentra 2.0 (A50120)
2007 Nissan Sentra...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
