M
   / M #1
Knotts farms
Farmal M john deer 1010
I have a M and wondering how I should bail hay with a hay bine and not run my hay over!
   / M #2
It is very simple, with a tricycle tractor you cannot help but run over the middle of the windrow you just laid down last time around the field. You could find a wide front for an M, but this is extremely rare. I think I have seen only one in my life, oh wait that was an H. Other wise you can find another tractor already with a wide front. If you are teddering the hay after you cut it, it will not make any difference. (unless of course it is alfalfa, every time you run over dry leaves you loose them all in the tire tracks.)
   / M
Thanks we can use the other tractor for alfalfa I would just much rather b on a res then green tractor but thanks for your help!
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
John Deere 8360R MFWD Tractor (A53342)
John Deere 8360R...
378647 (A51573)
378647 (A51573)
2017 Ford Fiesta SE Sedan (A51694)
2017 Ford Fiesta...
2014 MAGNUM PRODUCTS LIGHT TOWER (A52472)
2014 MAGNUM...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
