M Series-Convenience Hydraulic Lever
   / M Series-Convenience Hydraulic Lever #1
Turkeyman
Columbia, SC
JD 4720 and 5075M
It appears that some M series tractors have a rear hydraulic convenience lever for raising/lowering the 3 pt arms. Is this standard on cab tractors? or hydraulic shuttles?
Thank you
   / M Series-Convenience Hydraulic Lever #2
since your talking about a cab tractor.i think its pretty common to have a rear hydro lever to keep you from climbing in an out of the cab while hooking up equipment.but id ask your dealer to make sure.
   / M Series-Convenience Hydraulic Lever #3
I have a M9540 Grand Cab. It was not offered as an option when I bought mine 4 years ago.
I have seen this on other tractors and it does look convenient.
My solution is to open the back window and reach in to operate the controls.
If I had this as an option I would certainly get it but it would not be a deal breaker.
   / M Series-Convenience Hydraulic Lever #4
we kept the back window for that reason as well.
   / M Series-Convenience Hydraulic Lever #5
We have never used the 3-point on our M8540, but I don't believe it has this option. An open window and a piece of PVC pipe or my cane works on my L5030 HSTC.
I agree it would be handy though as mentioned not a deal breaker.
   / M Series-Convenience Hydraulic Lever #6
It wasn't an option that I know of, but would sure be a nice. I do like the PVC pipe through the back window idea.
E/S
   / M Series-Convenience Hydraulic Lever #7
E/S
That was one of the many tips given to me by TEXASJOHN.
   / M Series-Convenience Hydraulic Lever #8
I made a small bracket and bolted it to the bar that goes from side to side of the ROP. There is enough room to run 2 small rods under it and hook to the remote lever and the 3 point lever. Then you have control in the back!!
I used 1/4" rod and put a small knob on them. I only did it on my L4240, the B7800 doesn't need one.
   / M Series-Convenience Hydraulic Lever #9
That will not work with the cab in the way.
It would probably take a cable set-up to make it work.
Think I will stick with pipe & window method for now.
E/S
2017 Ford Explorer SUV (A50324)
2017 Ford Explorer...
2018 KENWORTH T370 T/A DUMP TRUCK (A51406)
2018 KENWORTH T370...
John Deere X310 Riding Mower (A50515)
John Deere X310...
2011 Chevrolet Equinox SUV (A50324)
2011 Chevrolet...
2013 Ford F-550 Altec AT40G 40FT Bucket Truck (A50323)
2013 Ford F-550...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
