LX5 Cutter Sheet Metal to bottom skid intersection
   / LX5 Cutter Sheet Metal to bottom skid intersection #1
mrf_la
La.
JD 790 / 2005
Ok guys, I've got probably a dumb question. After I finished the yard and a little work along the fence line, I pulled the 790 onto the concrete to check it all out; raised the lx5 and noticed I could see just a sliver of daylight along one of the sides. Along the side between the sheet metal skirt and lower lip or skid on the bottom was about 1/32 or 1/64th of an inch clearance between the welds; just enough for a little light to get through. Is that a defect in the LX5 or just the way they are made. You've got 3 welds on each side maybe then it looks like the sheet metal just sits on the bottom skid between the welds; usually covered by the paint I suppose.
Has anyone noticed this slight clearance or is it supposed to be there?
   / LX5 Cutter Sheet Metal to bottom skid intersection #2
I think its normal as they don't weld the entire seam.
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2014 Acura ILX Sedan (A51694)
2014 Acura ILX...
Adams 8 Ton Weigh Hopper (A52748)
Adams 8 Ton Weigh...
2019 MACK GR64F TANDEM AXLE CEMENT MIXER TRUCK (A52577)
2019 MACK GR64F...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2007 BobCat S175 Skid Steer (A52384)
2007 BobCat S175...
