LX410 4 years and 875hrs later
   / LX410 4 years and 875hrs later #1
TnAndy
Veteran Member
East Tennessee
Yanmar LX410...IHI 35J excavator Woodmizer LT40
Fan belt broke the other day. Something the dealer didn't stock....3 days to get one. In the mean time, I went to local auto parts store with the old one and they cross referenced it with two other brands. Bought one there. Seems sorta early for a belt to break....my last tractor had 2500hrs and 13yrs on the original belt.
Had enough hydraulic hoses fail over the last couple years on the front end loader that the last time I was at the hose shop, I had them make me up a complete set so I won't have to stop and go to town, I can just run to the shop, grab a hose and replace. Problem with losing a hose is the loader DIES in whatever position you are in, and you may, or may not, be able to drive it back to the shop to change a hose. Sorta unhandy.
Also replaced a curl cylinder for the second time about 6 months ago. First time, it blew the whole rod end out the tube, damaging the threads on the tube so I could reuse it....they replaced that one under warranty, but ever since I put that one on, the curl would leak down....you could almost watch it "un-curl". SO, I checked on a packing kit, and for not much more, you can buy the whole cylinder (about $175)(Kit was $120 !! ).....so I bought a cylinder, and this time, it doesn't leak down. Apparently, the FEL hydraulics is made by the minimum bid subcontractor.....
Then my fuel stoppage issue started back....like something was in the tank again (see previous post on this issue) intermittently blocking fuel. Tractor would simply stop at random times. Wait 30 seconds, crank a couple times and it would run until the next time.
Changed fuel filters (both the main one on the engine, and the bowl one under the right fender)....no effect.
Pulled the line off the tank, put another line on it leading to a fuel can and watched it drain the whole tank with no slow down in feed.
Then I started listening to the little booster pump...the one mounted under the right fender on top the first fuel filter bowl. Before, when key is on, you'd hear a steady 'tick-tick-tick'. Now it was steady, then a 'whrrr' sound....then back to tick-tick-tick. Made me suspect that pump was bad, so I ordered one ($124 for a crappy little fuel pump), replaced it, and that seems to have solved the fuel stoppage issue....knock on wood......
Life of a Yanmar owner I guess. Maybe my memory has faded, but the 220D I bought back in 1984 didn't seem to have nearly this many issues.
   / LX410 4 years and 875hrs later #2
Luckily sounds like nothing major, just a bunch of nickel and dime stuff. You keeping it?
Oh yeah.....I'm keeping it. Still a WHOLE lot better tractor than the New Holland 1925 it replaced.....WHOLE lot better.
   / LX410 4 years and 875hrs later #4
Very annoying problems that should not be there. Hope you have kept Yanmar apprised of these issues.
   / LX410 4 years and 875hrs later #5
I have never had a loader that stayed on the tractor before this one. I have wondered how to be proactive about hose maintenance. Do you get any warning at all. Do they just blow out? What was your experience. Sounds like no warning. I sure do not want to go through having one fail at a time due to age. 850 hours is a good amount of work but I have no idea of what age or usage says about hose life. Sun sure plays havoc so some more affected than others. Then there is power steering to think about. Hate down time. Basically is ruins a 300 mile trip to work on my farm😁
   / LX410 4 years and 875hrs later #6
I have never had a loader that stayed on the tractor before this one. I have wondered how to be proactive about hose maintenance. Do you get any warning at all. Do they just blow out? What was your experience. Sounds like no warning. I sure do not want to go through having one fail at a time due to age. 850 hours is a good amount of work but I have no idea of what age or usage says about hose life. Sun sure plays havoc so some more affected than others. Then there is power steering to think about. Hate down time. Basically is ruins a 300 mile trip to work on my farm?de01
My buddies new Kubota blew a loader hose within the first 50 hrs... And the hoses on my track loader have almost 2000. I'm sure it has more to do with chance (manufacturing anomaly) than proactive maintenance.
   / LX410 4 years and 875hrs later #7
Next time buy a Kioti.. Knock on wood.. They really are great tractors..
   / LX410 4 years and 875hrs later #8
Yes they are ... ALMOST as good as my Massey's have been... Almost.
   / LX410 4 years and 875hrs later #9
If I remember right you had more issues with your previous CK 20 in 200 hours than I have had with my DK 35 in 2000 hours.
   / LX410 4 years and 875hrs later #10
I have never had a loader that stayed on the tractor before this one. I have wondered how to be proactive about hose maintenance. Do you get any warning at all. Do they just blow out? What was your experience. Sounds like no warning. I sure do not want to go through having one fail at a time due to age. 850 hours is a good amount of work but I have no idea of what age or usage says about hose life. Sun sure plays havoc so some more affected than others. Then there is power steering to think about. Hate down time. Basically is ruins a 300 mile trip to work on my farm��
Being out in the weather can shorten the life of hydraulic hoses.
If they rub on anything that wears into them they will not last long.
But normally hydraulic hose should last thousands of hours.
NPK GH-9 Excavator Hammer (A50774)
NPK GH-9 Excavator...
Ford 1710 Tractor (AS IS) (A50774)
Ford 1710 Tractor...
2013 Ford F-250 XL (A50120)
2013 Ford F-250 XL...
2018 Ford F-250 Reading Enclosed Service Truck (A50323)
2018 Ford F-250...
2011 TRAIL KING LOWBOY TRAILER (A50459)
2011 TRAIL KING...
Blue Diamond Quick Attach Brush Mower (A50514)
Blue Diamond Quick...
