Hi,
It's been a lot of years since my last post, still have the same 1996 LX178. This year I did full maintenance, changed trans oil, coolant, new plugs, belts for the deck, shined it up like new. Then, of course, it returned the favor by starting to run poorly. Engaging the PTO would immediately kill the motor. I checked the PTO, electrically it was in spec. Found a thread about how sensative the carburators on these engines, so got a new can of carb cleaner, sprayed it in the jets and on choke plate, etc. They are a little shinier now, but they were not horrid. Ran much better, huge improvement, and I can engage the PTO and while it sounds harsh, it gets the deck going. I did lubricate the deck, sharpen/balance the blades, the whole assembly (44" pirhana mulching deck) turns quite freely. I still suspect the PTO or the charging system may have an issue.....
Anyway, my dad (has a Kubota diesel) suggested engaging the PTO at lower throttle, so I tried that, killed the motor. Fired up again, got the deck going, starting on the lawn and a few minutes in I'm smelling fuel.... Odd I thought... pulled up on the concrete, and it's leaking fuel. Shut down immediately. No further damage other than the original fuel pump failed. The replacement part has the extension hose to not dump fuel right on the muffler. Whew, coulda been a lot worse.
Put the new pump on today, and it starts right up when cool/using the choke, then after 5-10 seconds it just dies. Almost like it's not getting fuel, but I can see flow through my newly replaced fuel filter. I did both of the gaskets on the fuel pump mount, and it is a JD part from a Deere dealer.
I wonder if I could be flooding the carb now with the new pump? I wouldn't think so, but I'm somewhat stumped at the moment. If I let it sit for a bit, engage the choke, it will start right up again and run for 5-10 seconds before stopping.
Any suggestions would be helpful.
Thanks,
Greg O.
Thanks,
Greg O.
