LX178 with 17hp kawasaki liquid cooled dying when warmed up or when blades are engage
   / LX178 with 17hp kawasaki liquid cooled dying when warmed up or when blades are engage #1
riko73
Rensselaer,In
john deere lx178
I pulled the radiator,totally flushed radiator and block. pulled and tested thermostat,works fine. Filled with fresh 50/50 coolant. Also new plugs, fresh fuel with system cleaner,cleaned carb. Battery is wore out but hooked up to a charger. She runs GREAT at full throttle for 10-12 minutes and dies. Wait 5 minutes and starts right up. Also when engine is up to temp,I engage the electric PTO,engine dies after 3-5 minutes. PLEASE HELP!!!! If anybody has any suggestions,I would GREATLY appreciate it. My e-mail is riktiff@yahoo.com if you prefer that route.
   / LX178 with 17hp kawasaki liquid cooled dying when warmed up or when blades are engage #2
Put in a new battery and try running it again.
I will give that a try mfreund.
New battery didn't help. Thinking its fuel feed. Put in new fuel pump, tested fuel flow sensor, works fine. I am able to run at half throttle now with blades engaged. If I throttle to high engine wants to die, I throttle down then back to half and she keeps running. Please help,, I have no hair left because I pulled it all out working on this thing!!!! Lol
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2011 Ford Edge SEL SUV (A50324)
2011 Ford Edge SEL...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
Year: 2010 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 81,045 Plate: Body Type: 2 (A51692)
Year: 2010 Make...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2015 Crane Carrier Co. Low Entry (LE2/LD2/LW2/LT2/ST2/SD2) Truck (A51692)
2015 Crane Carrier...
