Stubee
I have a 1992 LX176 with a Kawasaki 14HP engine I bought used about twenty years ago. It has been a workhorse & I’ve had very little trouble with it. It has been blowing oil smoke at start-up and early in load (bagging) conditions for 5 + years but soldiers on. Use is in Michigan.
It starts fine cold but the past few days this happened: turned it off to gas it up and it wouldn’t start, just vigorously cranked until it flooded. I let it sit for several hours, it started right up, bagged one run of leaves and it suddenly cut out as though I’d left the seat. It again cranked but flooded. Left it overnight, pulled the plug and cleaned it, same quick cold start. I ran it around at near full for about two minutes as it didn’t want to idle down and it suddenly shut down again and wouldn’t start. Throttle position on restarts makes no difference.
So it’s getting fuel, air filter is clean, oil clean and full even though it smokes some, spark plug looks good. Towards the end of this it is not holding low idle well like it has forever. So I’m thinking maybe coil and/or igniter + spark plug. The problem is it has the FC420V AS-10 engine and parts are listed for every other AS-number variation known to man but not the -10. Do any of you guys know if the AS-10 shares parts with another, like the AS-9 etc?
I’m calling the Deere dealer tomorrow but thought I’d ask here first. Thanks.
