LX 665 starting problems
   / LX 665 starting problems #1
kitty1011
detroit, mi
jd 320
Hello My 1998 lx665 will not start unless I hot wire the fuel pump. If I put 12v to the fuel pump then the thing will start fine with the key. I have to turn the key on and let it do the glow plug count down before I sit down in the seat or the screen on the skid steer shows "ERROR03". It will still start and run with the error code on the screen, but I cant arrow through anything on the screen when the error code is displayed. If I let the count down go to zero and then sit in the seat, the board does not show the error code and I can arrow through the menu on the board seeing temp, hours ect.... One guy said its the board that is the problem, but I have heard others say its a solenoid. How can i Figure out what it is? I have also heard its near impossible to get a board for these units. Is there a source for the boards in these units? The skid steer will operate fine with the pump hot wired so I have been using it hot wired for a while now, but would like to figure out how to get it running as it should be.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
2016 FORD F-150 (A50854)
2016 FORD F-150...
INGERSOLL RAND COMPRESSOR (A50854)
INGERSOLL RAND...
2025 Swict 78in Bucket Skid Steer Attachment (A50322)
2025 Swict 78in...
2019 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2019 Ford F-150...
