LX 665 heater control
   / LX 665 heater control #1
EyeDigU
New HollandLX-665
LX 665 New Holland heater fan works but no heat. Radiator is full, unit gets warm but I don't think it is circulating through the heater core (unit has factory heat and ROPS, glass, etc.) What should be checked first? Any fuse or relays or is it only a manual lever/switch? Need some help fast as a storm is approaching and I use it for snow removal. Can't locate my manual. I'm batting zero and now I'm in the 2-minute drill! Thank you.
   / LX 665 heater control #2
there should be a heater valve in the overhead by the blower assembly. Most are manual with cable but I think there were some electronic packages also. Hopefully the manual version with cable for you?
I just came inside from freezing and that's what I found. Cable operation with electric fan and air bound. Now I'll have heat and won't freeze during the storm. Thank you for your reponse. Virginia is okay - Busch Gardens 3 times and Virginia Beach twice!
2022 KMC 5610 LOT NUMBER 212 (A53084)
2022 KMC 5610 LOT...
2011 IC Corporation PB105 School Bus (A52377)
2011 IC...
2023 GMC 3500 Bed (A51573)
2023 GMC 3500 Bed...
JOHN DEERE S780 LOT NUMBER 36 (A53084)
JOHN DEERE S780...
Pallet of (11) 10 Lug Misc Wheels (A51573)
Pallet of (11) 10...
