LX 5
/ LX 5 #1
unreconstructed
Platinum Member
West Texas
JD 5325 JD 5203 JD 2320 LT 133
Seems like I read a post about someone sharpening the blades on an rotary cutter and getting comparable results to a RFM. Had considered doing that and wondered if anyone had any thoughts on the issue?
Thanks.
/ LX 5 #2
I have an LX-6. It gets mixed duty, brush and grass. So I do not put an edge on it. If all you do with your LX-5 is cut grass then a sharper blade will likely give you a cleaner cut; but probably not as clean as a RFM. But if you do mixed cutting, a blade with an edge on it is going to get dinged up real bad and defeat the purpose.
/ LX 5 #3
I agree with N80. Rotary cutters can get out of balance pretty quickly when the cutting blades start to lose material from knicks, gouges, chips, etc.. If you did sharpen the blades I would be real careful about keeping the blades the same weight. There have been a couple of threads in the past where posters sharpened their RC cutting blades and were happy with the results, and if I remember correctly :confused: there was an entry about the cutting blades losing their temper from the heat of blade sharpening. Just my $0.02- Jay
/ LX 5
Thanks for your input. I too had reservations about sharpening the blade.
2021 CATERPILLAR 279D3 SKID STEER (A65053)
2021 CATERPILLAR...
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
(9) STAMPED INTERNATIONAL FRONT WEIGHTS (A64278)
(9) STAMPED...
2025 iRanch IRTPL 10,000lbs. Two Post Automotive Lift (A64194)
2025 iRanch IRTPL...
2010 Mercury 15HP Tiller Four Stroke Outboard Boat Motor (A64557)
2010 Mercury 15HP...
2025 Swict 84in Bucket Skid Steer Attachment (A64553)
2025 Swict 84in...
