LX 5 cutter
   / LX 5 cutter #1
Kahuna
I know its not the season but I have a 3320 and a MX 6 mower. I actually bought the MX 6 for another tractor but would like a LX 5 for the 3320. The MX 6 is a little heavy for the 3320 when in big grass.
Any experience out there with a 5 foot chopper on the 3320 (or comparable 32.5 hp) and does anyone know of any out there for sale. I need the I-match. I know the LX is no longer made but thought there be a good used one out there.
   / LX 5 cutter #2
I have a LX5 on a 4310 - which is 32 HP and it has no problem cutting anything.
   / LX 5 cutter #3
I have an MX-5 on my 3320 and it works great. It seems to cut the field grasses cleaner than the LX I had on my 2520--I believe that MX series cutters have higher blade tip speeds and that helps get a "better" result in grasses. I don't think it is really that much better--so if you have no need for the extra "oomph" and brush cutting capabilities of the MX's then the LX-5 would be fine--you may even be able to go to an LX-6.
   / LX 5 cutter #4
Kahuna - will the MX6 be up for sale?
   / LX 5 cutter #5
My dealer has new LX-5s in stock still. Premier Ag & Lawn in Ennis, Texas.
I have a slightly used Imatch that I no longer use. Cat 1 version.
D.
   / LX 5 cutter #6
i've got an lx5 on my 790 28hp and have had no issues w/ power. i think if you were to try on cut at a fast rate of speed, you may start to bog down a bit in very heavy grass. i've run mine through some thick brush as well saplings and whips of 1in diameter and some thick briars, still no power loss although i was creeping along in 1st gear.
   / LX 5 cutter #7
He has a MX6 now and is looking at going to LX5.
I have to say - you can put too much mower behind a tractor. My JD 2210 wouldn't handle a LX-4. That is when I knew it had to go.
D.
UNUSED GRASSROOTS IMPLEMENT 5' LANDSCAPE RAKE (A54756)
UNUSED GRASSROOTS...
INDUSTRIAS AMERICA F12T HYD TILT LAND LEVELER (A51406)
INDUSTRIAS AMERICA...
19015 (A53422)
19015 (A53422)
2007 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51406)
2007 FORD F750 XLT...
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
