Joe1
Platinum Member
lx-4 Rottary or Bush Hog 5\' for 20 PTO HP
Just joined this forum and just bought a used JD 770 with 25 gross and 20 PTO HP. The JD dealer initially suggested an LX-4 with slip clutch, but I'd like a 5'. No LX-5 in stock for 3 weeks, but a Bush Hog with shear pin. Bush Hog is about $100.00 cheaper. I'll be cutting 4-5 acres of 4-5 ft tall weeds on a totally flat lot. After the initial cutting, I'll keep it down, but it hasn't been cut all year. No saplings, just weeds, fennel, etc. I nntend an initial cut set as high as the mower will go, then a recut. Will the 770 handle the Bush Hog Squealer 60" in these conditions. I believe it will, in the lower gears. Is the JD better built for the extra price? Supposedly the LX slip clutch is self adjusting. There are some gopher mounds, etc there so I don't want to spend my cutting time changing shear pins.
I could sure use some expert opinion on this. Thanks.
By the way, I've reviewed about every JD related Posting from the last 6 months. Lots of good advice with enough humor to keep it interesting.
