lug nut size on ford 350 / 450 drw.. etc
   / lug nut size on ford 350 / 450 drw.. etc #1
Soundguy
Old Timer
Central florida
RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
just thought about it.. bu I wanna hit the tire shop and gran a handfull of spares.. nothing like changing a tire on the side of the road and kickin gthe pan that has yer nutz in it...
anyone know the size?
thanks
soundguy
   / lug nut size on ford 350 / 450 drw.. etc #2
thanks
soundguy
Just ask the tire guy what size you nutz are I bet he can tell you!!! :D:thumbsup:
   / lug nut size on ford 350 / 450 drw.. etc #3
They changed, depending on the year. A lot of the 450s came with 19.5 wheels also, where the 350 had 16" wheels.
yep.. my 450 has 19.5 and my 350 16"
   / lug nut size on ford 350 / 450 drw.. etc #5
Studs are 9/16" unless they changed recently.
   / lug nut size on ford 350 / 450 drw.. etc #6
Depends on the model years in questions. The Super Duty F350 and F450 are metric M14x 1.5 or M14x2.0 depending on model year. The Pre-99's were 9/16.
   / lug nut size on ford 350 / 450 drw.. etc #7
Yup the stud are varied. My 2001 F-350 has the really coarse threaded studs. The 16" rims only work to 2004 then you need a 17" rim. The 8 lug pattern is metric too since 1999, it won't interchange with the old standard 8 bolts. The newer 17 and 18" rims are backwards compatible to the 1999-2004's, they just came about to fit the bigger brake rotors.
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A51692)
2003 International...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2803 (A50460)
2803 (A50460)
23311 (A51694)
23311 (A51694)
2021 PETERBILT 567 DAY CAB (A53426)
2021 PETERBILT 567...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
