Snowblower Lucknow SnowBlower with Comer Gearbox Type T27D
   / Lucknow SnowBlower with Comer Gearbox Type T27D #1
70 plus
Uxbridge, Ontario
Kubota B3200, JD LT 166, JD 110
I need some advice. This year in some really heavy and deep snow my 72" Lucknow Snowblower that has worked like a charm for many years would cease blowing in heavy or really deep snow but the PTO kept turning until I took some of the pressure off and it would start blowing properly again. What I am wondering is if one of the gears in the Comer Gear Box may be sripped or worn to the extent that under heavy loads the auger would stop turning or if the problem was with my Kubota B32 that I use for snow blowing? Any comment or suggestions would be appreciated.
   / Lucknow SnowBlower with Comer Gearbox Type T27D #2
Is this a front mount or rear mount blower? I doubt gear box would work, quit and work again but anything is possible.
It is Rear mount I also need to use the bucket on some of the deeper snow.
   / Lucknow SnowBlower with Comer Gearbox Type T27D #4
With rear mount I would question PTO shaft spinning on input shaft to gear box since I think most blowers the shaft is straight thru for running the fan.
   / Lucknow SnowBlower with Comer Gearbox Type T27D #5
Possibly a key sheared off in the auger drive; gearbox or sprockets.
I'm now 80 Plus but do not fancy pulling the gear box apart unless I know for sure that is where the problem is. For now I have just parked the snow blower and will soon put the mower on. If that does not operate properly then I will know the problem is in the tractor PTO
   / Lucknow SnowBlower with Comer Gearbox Type T27D #7
So the fan is turning and the auger stops in heavy going? I would check the two flanges that the auger shear bolt connects. I rebuilt my 72" Lucknow clone several years ago and found those two flanges rusted securely together. If the shear bolt is cut, the flanges might stick together under light load but slip in heavy going. Just a suggestion based on my experience. Good luck!
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
71052 (A49346)
71052 (A49346)
2017 Kawasaki Mule 4010 4x4 Rescue Utility Cart (A50322)
2017 Kawasaki Mule...
2018 Wacker Neuson WL 38 (A51039)
2018 Wacker Neuson...
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
2020 CHEVROLET Z71 TEXAS EDITION TRUCK (A51406)
2020 CHEVROLET Z71...
