Rotary Cutter lubrication
   / lubrication #1
jimbo64
lubrication-bush hog gearbox
bought a used bushhog and not sure how to lubricate the gear box. has two hex head set plugs in it, one above the other. top one is larger and bottom one much smaller. I think the top one is the fill plug and the bottom one is where one checks the fill level. { i guess could almost be the drain plug} ques, do i fill until gear oil comes out the bottom hole:confused2: or fill up to the top plug hole
   / lubrication #2
Re: lubrication-bush hog gearbox
Cant say for sure without seeing it. Most gearboxes are full at the bottom of the input shaft. Ken Sweet
   / lubrication #3
Yes, that is the way my bush hog gear box is ..fill at the top until it runs out of the one on the side or bottom and then put the nut back in.
   / lubrication
thanks guys for the inputs, i'll keep checking bottom hole and if gear oil comes out, i'll assume she's full. Have a great one
2016 Ford Explorer...
2012 Ford F-250 Ext. Cab Omaha Service Truck (A50323)
2012 Ford F-250...
2012 Ford Fusion SE Sedan (A50324)
2012 Ford Fusion...
2003 Lincoln LS (A50324)
2003 Lincoln LS...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A50323)
2017 Mack GU713...
Kent KHB3G Q.A Hydraulic Breaker (A50121)
Kent KHB3G Q.A...
