Lubing treadle shaft - 3016
   / Lubing treadle shaft - 3016 #1
oldpilgrim
Elite Member
SE Ma
2014 Mahindra 3016HST
Lubing treadle shaft - 3016 HST
While doing my 100 complete lube/change, I could find no way to lube the treadle on it's shaft.
Any ideas ?
   / Lubing treadle shaft - 3016 #2
Where is that shaft getting ready to do my 100 service and thanks again for all the info you have posted.
Sent from my iPhone using TractorByNet
up under the right floor inboard of the brake pedal shaft.
But you don't have what I have since you have the shuttle version. I'll bet you have other shafts to grease that I don't have.
   / Lubing treadle shaft - 3016 #4
I grease all zerks as per manual and spray white lithium grease on all linkages that has no grease fitting
Most of what I said doesn't apply to your tractor yours being a shuttle shift. I don't know what you're required to do for your 100 service.
   / Lubing treadle shaft - 3016 #6
Same as yours but no hst filter the rest is the same I believe
Does your tranny call for hydro fluid or grease? how about the front axle?
   / Lubing treadle shaft - 3016 #8
Transmission calls for 36quarts of hydraulic oil and front axle calls for 4.2 quarts of hydraulic transmission fluid
   / Lubing treadle shaft - 3016 #9
I am thinking there are talking same oil for front axle?
yup the same for mine. Same fluid front and rear.
377811 (A48836)
377811 (A48836)
1993 Ford F700 Stakebody Flatbed Truck (A51692)
1993 Ford F700...
2020 JOHN DEERE 5125R LOT NUMBER 213 (A53084)
2020 JOHN DEERE...
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
Ford NAA Jubilee Tractor (A53472)
Ford NAA Jubilee...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
