leohinojosa
Hello everyone I am new to this forum and I would like some assistance.
I recently purchased a Cub Cadet LTX1050, when i spoke to the individual who sold me the tractor he said the only issue he had was the PTO belt would have to be replaced soon. So I drove an hour and a half and picked it up after viewing it run and cut. I felt i got a great deal as it had 50 hours on the engine.
Once i got it home and started to mow within the hour the middle spindle made a terrible noise. After removing the deck I discovered the spindle had gone bad. I ordered a new spindle and thougth perhaps the man misdiagnosed the belt issue and it was instead a spindle issue. I ordered a new spindle and during my installation I had noticed one there were another set of holes however one of the holes was completely unusable. So I drilled new holes and reinstalled. I did notice the blades were a bit worn so i replaced the blades as well.
I began to mow and i noticed the PTO would engage for a few minutes and then it would disengage. I cut normally about 3 acres of my property, leaving the rest for habitat and work.
After some research I have discovered the PTO is a known issue within the Cub Cadet brand.
Ive read some where the fuse may be bad, however i do not know where the fuses are for the PTO. I have read to follow the wires and look for a short some where but as i follow the wires from the PTO they are not exposed. They are within a plastic housing and they go behind the gas tank to the PTO knob.
I am new to doing my own repairs on lawn equipment. Most of the repairs Ive done thus far ive seen on you tube or read what to do. Unfortunately I am lost with this issue.
I did notice when i do cut my lawn that there is a strip of uncut grass. I wonder if this is due to the blades not being fully engaged ? But they are new and they do rotate..Or is this due to a different issue ?
I have read that some PTO are adjustable however i have not discovered if the PTO gap is adjustable in the ltx1050 model or if it is what the gap is suppose to be
Im sorry for all the questions ..Thank you
Leo
Leo
