LT166 with K51 Won't Move
   / LT166 with K51 Won't Move #1
mac5551212
John Deere LT166
I just picked up a LT166 for free and the motor runs great and it is in good shape but it won't move. I just pulled apart the transmission and all of the gears were in great shape and the pistons and cylinder walls looked to be smooth and in good condition. The drive belt is rotating the shaft in the transmission when I remove the brake but I am getting no movement out of the axle shafts. When I refilled the K51 trans I could only get about 1.5 quarts into it and it asked for around 2.3 quarts. Could it be that it is just low on fluid and or needs to have air bled from the system?
Managed to get the other quart into the transmission. Needed to remove the large plug, pull out the spring, and then pull out the flat fliter. The oil can't pass through the filter unless it's under pressure. Tractor is good as new. It even pulls wheelies!
   / LT166 with K51 Won't Move #3
Congrats, it feels good to easily fix stuff yourself and save a bunch of money.:thumbsup:
2015 Ram 1500 Crew Cab Pickup Truck (A49461)
2015 Ram 1500 Crew...
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
CAT 312C (A50854)
CAT 312C (A50854)
AMCO F42B-3626CS 13ft Pull-Behind Wheel Offset Harrow Tiller (A49461)
AMCO F42B-3626CS...
2016 CAT 980M WHEEL LOADER (A50854)
2016 CAT 980M...
2021 John Deere 6130M 4WD Tractor w 620R Loader, Premium Cab, 250 Hours (A51039)
2021 John Deere...
