LT150 Tire Repair
   / LT150 Tire Repair #1
Skidmark25
North Shore, MA
B7610
Hi All - I have a JD LT150 about 12 years old or so, still running strong. 2 of the 4 tires (1 front & 1 rear) go flat in a day or two. Do I need to replace the tires with new tubeless tires or can I just put in a couple of inner tubes?? Thanks . . .
   / LT150 Tire Repair #2
I would just tube them unless you have large side wall cracks that the tube would protrude through.
   / LT150 Tire Repair
Thanks Randy - Thought so, think I just needed to double-check. . .
   / LT150 Tire Repair #4
I put new front tires on last year because of air leaks and after checking the prices for the rears ( 120 each) think I might tube them too. Don't think I want to dump $300 in rear tires on my old L130.
   / LT150 Tire Repair #5
Perhaps the valve stem assembles are leaking? I had one leaking from around the rim valve stem hole recently. I also tubed the front tires on my STX and it is working well. The small tires are a challenge to dismount, but the FEL with forks make an easy way to break the bead away from the rim. The tubes were less than $8.00 at my local John Deere Dealer and were Carlisles.
Good luck with the project.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
2004 INTERNATIONAL DURASTAR 4300 (A50854)
2004 INTERNATIONAL...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
WITTIG VACUUM PUMP (A50854)
WITTIG VACUUM PUMP...
2022 JOHN DEERE 332G (A50854)
2022 JOHN DEERE...
