LT1046 PTO Inop
   / LT1046 PTO Inop #1
Redcon1
Glenville, PA
2006 Cub LT1045SE
LT 1046- Haven't started the tractor for 3 weeks (too dry to mow). Attempted start, battery appeared dead. Jumped from my car (per procedures in manual) and tractor fires right up... but PTO will not engage blades. Dashboard amp meter jumping wildly, also. I killed the engine when I hopped off the seat, so I tried the jump once more and same result-- PTO no worky. Then the engine died all on its own, so I called it a night.:mad:
Any ideas? 20amp fuse under the hood is fine.
Thanks, Dave
   / LT1046 PTO Inop #2
I know this may not be what you'd like but did you hook the cables up backwards? Where it was stored is it possible that mice might have chewed some wires?
   / LT1046 PTO Inop #3
Try to start the pto with jumper on to see if battery has a dead short.
   / LT1046 PTO Inop
Good idea... I'll try that this evening. Think I should pick up a battery on the way home just in case?
btw, I know the cables were hooked up correctly, and all the wiring I traced looked fine.;)
   / LT1046 PTO Inop
Replaced the battery and all is well. :)
2018 FORD F-550 (A50323)
2018 FORD F-550...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A52128)
NEW 2025 Load...
Toro Workman Low Profile Spray system 175 (A50322)
Toro Workman Low...
2018 Ford f150 (A50323)
2018 Ford f150...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2016 Ford Explorer...
