LT1045 Transmission Problems
   / LT1045 Transmission Problems #1
Jim_the_Gardner
North Central Massachusetts
Hello,
I should have checked with the experts on this site long ago. I am here looking for advice on the CC LT1045 transmission. I bought the 1045 from Lowes back in the summer of 2005 and have not had any issues with it up to the end of the cutting season last fall. I have about 60 hours on the tractor. On my last cut when climbing a fairly steep hill on my property the transmission for lack of a better word "went out". This happened when I was stopped on the incline and attempted to start going. Along with the lack of forward motion there was a noticable grinding sound coming from under the tractor (tranny). After pushing it back up the hill and back on flat ground I tried releasing the brake to go forward and again no forward motion, only grinding. I haven't had the thing serviced since this happened at the end of the season and I am holding out little hope that the tranny is still any good. I am also hoping someone on this site may be able to give me some advice about what I should be checking looking for, if anything? Does anybody have any advice before I shell out what will likely be a large amount of money on a new tranny? Thanks.
Jim
   / LT1045 Transmission Problems #2
Jim does it go in reverse? If indeed this is a hydrostatic transaxle issue, you do have a 3yr manufacturer warranty on it. I'd call the Lowes you bought it from & ask the garden center where to take it. Either that or stop by a CC dealer convenient to you and ask.
Joel
   / LT1045 Transmission Problems #3
Yes, it needs to see a dealer. There have been some issues with the belt tensioners and Hydro-Gear transaxles on those models. Should be under full warranty.
-Fordlords-
Thanks to you both for the quick feedback!! I got some time to get the tractor out this weekend and get the deck off. Sure enough, the drive belt had jumped the belt tensioner and that was the problem. I put the belt back on over the tensioner and voila, problem solved. Now if I can only get the dang engine to run right :-(
2011 BMW 5 Series 550I GT Sedan (A50324)
2011 BMW 5 Series...
2012 MACK GU713 DUMP TRUCK (A51406)
2012 MACK GU713...
2006 International 9400i (A52128)
2006 International...
2003 STERLING ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2016 HINO 268 BOX TRUCK (A51219)
2016 HINO 268 BOX...
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
