LT1042 runs like a BEAR
   / LT1042 runs like a BEAR #1
TPajak
UpState NY
Cub Cadet LT1042
borrowed a 17cu. tow behind wagon to clear rocks..filled it with roughly 700lbs. and pulled it all around my yard with little hills and dips...never broke a sweat....ran it full like this for around 20-30 mins and afterwards i felt the tranny..was warm but not hot like i expected....bought this Cub from Tractor Supply here in Upstate NY...very happy with the performance..the only complaint i have is the cupholder...went to drink my water and had some clippings in it...they really need it to be on the other side..DO YOU HEAR ME MTD>>>THE OTHERSIDE!!!!....lol /forums/images/graemlins/laugh.gif
glad to see everyone has an interest in the post..no lies in it whatsoever....
i do have a question if anyone can tell me...
Can i switch the 1554 front wheel/tire and the 1550 back tire/wheel with mine?...liking the lower profile look..
the 1554 has a larger front wheel than the 1550...
the 1550 has a larger rear wheel than the 1554...but the specs claim they are the same on the website...must be talking about the height of the overall package...
   / LT1042 runs like a BEAR #3
It's good to see a positive 1000 series post! There's not too many of them. I think you caught everyone off-guard! /forums/images/graemlins/blush.gif As far as the tire/wheel swap thing, you'll have to compare the front spindles and rear hubs to see if it's a direct swap. You can go thru the CC website for parts diagrams, but you'll need a model and serial # from a 1500 series to compare. Hopefully a 1500 owner will donate their numbers for the sake of science!?!?
G/luck
Joel
   / LT1042 runs like a BEAR #4
Yes, it's great to hear someone has a properly working 1000 series for a change /forums/images/graemlins/smile.gif Yes, you'll need to do what JTKub said, and also measure the overall height of the new tire-wheel combo you want to use as if you change that, it can effect the height setting on your mower deck. If the 1550 rear wheel/tire is substantially taller then that used on the 1042, and I think it is, that could set your deck to too much of a forward lean which would not be good.
-Fordlords-
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
2019 BOBCAT T630 COMPACT SKID STEER TRACK LOADER (A57024)
2019 BOBCAT T630...
UNUSED JCT HYD AUGER (A57193)
UNUSED JCT HYD...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
UNUSED IRANCH IRTPL 10,000# TWO POST LIFT (GRAY) (A57193)
UNUSED IRANCH...
UNUSED FUTURE HYD MINI THUMB CLIP (A57193)
UNUSED FUTURE HYD...
