LT1042 pto stopped working
   / LT1042 pto stopped working #1
jgarnertn@yahoo.com
How can I find the cause of my pto not working? It doesn't even make a sound when the pto switch is engaged. How can I know the switch is good? Is the hot wire to the pto clutch fused? If so, where is the fuse? Where can I find a wiring diagram? Thanks.
   / LT1042 pto stopped working #2
the attached schematic is for a 2005 model year.LT1042...
To my knowledge, there is no separate fuse for the clutch cicuit. To troubleshoot, you might try searching this board for similar posts.. or - with your 11 digit model number and serial number - go to the cub website and from within the customer service center tab at the bottom, download the LT1000 series service manual section for the electric clutch PTO...
good luck.
   / LT1042 pto stopped working #3
Check the relay on the PTO circuit. Tap it hard.
   / LT1042 pto stopped working #4
I have the same problem, the pto switch does nothing. Did you ever fine the cause of this problem? Thanks for any help
2017 Chevrolet Tahoe SUV (A48082)
2017 Chevrolet...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A48081)
2000 Thomas Built...
BANDIT ZT1844 RUBBER TRACK STUMP GRINDER (A50458)
BANDIT ZT1844...
2020 Kubota Z723KH 48in. Zero Turn Commercial Mower (A50324)
2020 Kubota Z723KH...
2025 K3325 UNUSED Double Garage Steel Barn (A50860)
2025 K3325 UNUSED...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
