LT1000 deck belt replacement
/ LT1000 deck belt replacement #1
bkenobi
Monroe, WA
NH T1510
I have a Craftsman 917.272201 lawn tractor which has had some modifications made to it by the previous owner (I assume). This tractor came with a 46" deck originally but when I got it, it has a 42" deck. I had pulled the deck to repair some damage and noticed that the belt that was on it was pretty tight. Yesterday after getting half way around my property I heard some flippity-flap from the deck and then no more blades. The belt still has one string intact, but I'm not sure if it's on the inner or outer diameter so measuring the length doesn't really help all that much. I can say that what I measured was 94" and from reading around various places, it looks like these tractors generally used a 1/2" x 95.5" v-belt. I'm leaning towards that being the right length but nobody had it locally on my initial search so I picked up a 94" and 95" from O'Reilly to see if either was close.
Does anyone know if a 42" deck always uses a 95.5" belt regardless of the engagement? Mine is electric but my last mower was manual and they looked very close to the same length though I didn't measure. I'm just trying to make sure whatever I end up ordering is right so I don't have to hassle with a return and longer delays.
/ LT1000 deck belt replacement #2
So the Craftsman site shows 144959 1/2”x95.5” for 38”, 42” and 46” decks for LT1000 and LT2000
I tried 95.5 and it was too short for whatever reason (couldn't get the deck to mount). I tried a 96.5 and it mounts correctly and feels like it has good tension (the tensioner is neither min or max position). I'll try this one and see how it goes. Should have pulled the belt to measure once I realized it was a different bed. Hmmm, wonder if I should pull the main drive belt too since I know the motor was swapped too.
/ LT1000 deck belt replacement #4
I had a similar problem with an LT... Too long, no engagement. Too short, blades wouldn't stop. Mechanical PTO was even worse to find that sweetspot for the right belt.
/ LT1000 deck belt replacement #5
Next time you have the deck off, snap a pic of the top of the deck.
/ LT1000 deck belt replacement #6
Perhaps if you check the belt you can find the numbers
to get a new one
willy
The old belt was too worn on the outer surface to have any printing left. I tried to measure it and came up with 94" but since it's shredded and down to 2 strands in that section, it would be hard to determine whether that's closer to ID or OD. The deck is nearly identical to the LT1000 that came with a 42" deck other than it was manual/lever actuated versus electric.
I was able to install the 96.5" belt the other day and had a chance to test it today. It seems to spin up just fine though it was raining enough that I didn't try to cut anything.
/ LT1000 deck belt replacement #8
So are you installing a tension spring on this?
174883 was the belt that the 42" inch used w/ the electric clutch along with a spring. 2002 and up?
It has a tensioner spring.
/ LT1000 deck belt replacement #10
It has too many springs if you are using this with an electric clutch. First off, remove the brake arms, hardware and their springs. Next remove the spring that hooks of the front of the idler cam. The actual tensioner spring that pulls back on the idler cam is not as designed, but I'm sure you can figure out tension once you have the 174883 belt installed.
I don't know why the brake arms are still on but figure with the springs on they are out of the way (the springs hold them open versus brake engaged like normal). I don't think they add to the belt tension but didn't look that close. I can say that there is a lot of force required to move the tensioner! Now that it's installed, it seems ok. I'll definitely remove some parts as you suggest if the belt comes apart again quickly. The last one was really cheap compared to what I installed so not sure if it failed because of age/use, bad design, or just because it was a garbage belt to begin with.
2018 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A60352)
2018 Chevrolet...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
Toro Three wheeler sand pro (A56859)
Toro Three wheeler...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
1996 Geo Tracker SUV (A60352)
1996 Geo Tracker...
Pallet of Four Pivot Wheels & Tires (A62177)
Pallet of Four...
