lt 1050 transmission issue
   / lt 1050 transmission issue #1
RodMunch
I have a 3 year old lt1050 with about 120 hours or so on it. So far its been trouble free. My mother used it the other day and thought the parking brake stuck cause it started fine but would not go forward or reverse. I opened it up and verified the brake was free. I could not push it even with the transmission lever disengaged. I started to play with the external transmission linkage near the transmission disengage lever and this solved the problem for now; however, I suspect that something still needs to be repaired or the problem will re-occur. Has anyone experienced a similar issue and how was it resolved?
Regards,
RM
   / lt 1050 transmission issue #2
If it worked at the transmition but not the petals I would get underneath it and check all the connections between the petals and transmition for any loose, missing or binding nuts, bolts or parts.
Case Ih 2388 Combine (A50514)
Case Ih 2388...
1263 (A50490)
1263 (A50490)
PENDING SELLER CONFIRMATIONS (A52141)
PENDING SELLER...
71066 (A49346)
71066 (A49346)
SELLICK S80J4E-2PS ROUGH TERRAIN FORKLIFT (A51242)
SELLICK S80J4E-2PS...
Quick Attach Accumulator Grapple (A50514)
Quick Attach...
