LT 1018 Electric PTO Pulley/Pulley Shaft Problem
   / LT 1018 Electric PTO Pulley/Pulley Shaft Problem #1
cfkenney
Kansas
Cub Cadet LT1018
I removed the electric pto pulley from the slotted pulley shaft (Key Timing?) in order to change the drive belt and no I am unable to get it back on, any suggestions?
A bunch of views but no replies, so I will ask this, how difficult is it to replace the crank shaft?
   / LT 1018 Electric PTO Pulley/Pulley Shaft Problem #3
I'm guessing that no one can understand how if it came off, it won't go back on. You ARE lining up the key and both keyways, right? Sometimes with a half-moon key it is a bit tricky to get the leading edge of the key to start in the keyway of the pulley. I just try to be sure that the keyways are both very clean (wire brush is good) so that the key can easily seat fully, then gently tap it into the shaft keyway, leaving the outboard edge just slightly (VERY slightly) lower than the inboard edge. Once you tap the pulley on enough that it just barely starts into the pulley keyway, it is sometimes good to again very gently tap the key again to "level" it so that it will easily enter the pulley keyway the rest of the way and not "cock". Granted, all hard to do while upside down and vertical with limited clearance and visibility!
Replacing the crankshaft would just involve removing and fully disassembling the engine.
- Jay
Thanks for the reply, I may have lost the key as I have just been trying to get the electric pto clutch pulley onto the crankshaft. I will take a closer look at it from another angle and see if I am missing the key.
Thanks again.
2023 LMC H40024 LOT NUMBER 190 (A53084)
2023 LMC H40024...
Hustler Raptor Limited Zero Turn Mower (A51573)
Hustler Raptor...
JOHN DEERE 4066R LOT NUMBER 23 (A53084)
JOHN DEERE 4066R...
JOHN DEERE 2032R LOT NUMBER 239 (A53084)
JOHN DEERE 2032R...
2025 New/Unused LandHero 16in Concrete Cutter (A51573)
2025 New/Unused...
